Corona Renderer 1.6 Release Candidate 10 is out now!
Everyone with an active FairSaaS or Box with Subscription license has access, and the download is in the usual location: Dropbox - Error - Simplify your life
(NOTE - to avoid scattered multiple threads with posts for each RC, the RC announcement post is being edited to highlight when a new RC is out just in case anyone doesn’t watch the daily builds thread :smiley: )
Here are the changes in RC10:
DR
  • Fixed slaves occasionally continuing to render after master already stopped
  • Fixed slave getting stuck while waiting for assets from master
Image Editor
  • Fixed wrong preselection of file name extension in Save all dialog.
  • Installer now creates a shortcut on desktop-
  • Redesigned the confirmation dialogs when opening/quitting with unsaved changes to make them more clear and descriptive
My Rendering info keeps disappearing ! whilst rendering
What info are you referring to? Are you using DR?
Interactive render keeps restarting forever when I use Camera Perspective: Tilt Shift specially on heavy scenes.
yes I had that issue quick fix: disable camera target and it should work!!! let me know.
Yes, I reported this problem for a previous RC. It seems to be a 3dsmax bug… That’s really painful, hope Corona team will find a workaround to solve it (probably is just not possible)
Hope so because shift lens + IR = essential for us… :confused:
All posts prior to this one were for RC 9.
now why didn’t I think of that! I have been jumping between physical and standard cameras hoping for a one solution! +1
+1 absolutely… would make life so much simpler if everything was in one camera node.
+1 This would be great!
Well not for everyone it wouldn’t. :smiley: We use a mixed Corona/Vray workflow and being able to use the exact same Physical Cameras is a great benefit. Justsayin’.
