It only proposes me 2026 during installation please help
main mail account is agence@jeudi.wang
Hi, you can use the unpack option in the installer. In the unpacked folder, you will find a readme file explaining how to install Corona manually.
If you continue to have some problems, please contact us at https://support.chaos.com/hc/en-us/requests/new
Thanks works fine.
Thos even that it is installed whe i re run the installer still no detection of the already manuaklkly installed corona.
cheers
Not sure why it’s not detecting the other 3ds Max versions for you. I am not aware of similar reports. Perhaps reinstalling 3ds Max could help, but I understand this is not the preferred solution…
For me, i had 2024 and 2025 detected, but not the fresh new 2026 i just installed before
i had to manually select it as well
happened on 2 workstations
Selecting manually is something else and is fine. Having the max version(s) greyed out in Corona installer when they are installed is not fine.
My guess is not proper installation of these 3ds Max versions.
