In my scene which takes 33 GB of RAM. When rendering corona render 4 hotfix 3. everything is fine. When rendering corona 5, cinema 4d turns off without warning after about 20 minutes of rendering. There is not even a bugreport or minidup in the cinema folder.
Only once I managed to get it bugreport, I attach to check what is happening.
waiting for some info.
Greg
Successfully uploaded as 1574372243_bugreports-21.11.2019.rar.Now please post the filename into your bug report thread. _bugreports_21.11.2019.rar (2.39 MB)
This is the entire program, not just the rendering stopping? At first I thought it might be related to my issue (https://forum.corona-renderer.com/Render Nodes Stopping ), but sounds like you mean the entire program instacrashes.
Hi
video: http://wrzucplik.pl/pokaz/1866341---wtvi.html
last seconds of the movie…
I noticed that this also happens if I’m outside the application window and wants to enter c4d again (as in the case of the movie).
PC spec.
cpu-AMD 1950 x threadripper
motherboard- MSI x399 gaming pro carbon ac
ram- g.skill flarex 3200 MHz, 64 GB
disc: SSD Samsung evo 970
EDIT:
The same scene, the same settings, the same computer, but corona 4 hotfix3 … comfortable work despite higher consumption of RAM. http://wrzucplik.pl/pokaz/1866357---nffd.html
I found a problem
The problem was RAM.
My RAM memory has XMP profiles at 2933 and 3200 MHz. Before Corona 5, on version 4, they worked well. After installing corona for c4d 5, I had to reduce the RAM clock speed, because it was dumping the c4d application from memory (as seen on the links above).
Now I have 2933 MHz on XMP1 profiles on G. Skill Flare X, DDR4, 16 GB, 3200MHz, CL14 (F4-3200C14D-16GFX). And so far everything works.
I think I helped something.
Greetings
Greg.
