As I remember, Corona Tile map is deeply inspired byr Bercon Tile map.
Is it possible to use different gap size X & Y on a map, as it was on Bercon ?
Actually, gap are uniform in vertical & horizontal value, and I cant suceed to avoid it…
Nope, not possible. There is however a feature request for that in Corona ideas portal. If you want to increase the chances of the feature to be implemented in the feature, i’d suggest to go the portal and express your support by voting. Corona Tiles - different gap/grout values for | Corona Ideas Portal
Please add this feature as soon as U can.
It is SO so annoying to have to get back to bercon-so unstable-map, just to be able to have a 0 gap on vertical or horizontal.
