Corona Tiles, with the connection Corona Multi Map. As an alternative to standard Max’s Tiles map.
Each tile can have an individual map (randomly).
I’d certainly have good use for something like that.
Ive been looking for something like this for ages.
+1 for sure!
Normally I’d be all for this, but isn’t the existing tiles map and bercontile enough?
Though a big problem with using multimap or even multitexture are corner conditions; unless uvw unwrapping fixes that…
Can we also get a 3d Tile maker too? roof tiles in particular. Maybe it would be part of the corona scatter?
steyin:
Damn i forgot about bercontiles…
I would loe this too, Bercon are useful but buggy…
Would like this. Bercon has issues with Corona IR so not the best.
+1, I can’t use bercontile because IT says it will mess up the render farm
Yeah not being able to use it with IR makes them difficult to use.
A really well done, really well maintained tile map would be fantastic.
For those who are affected: which part of Bercon doesn’t work with IR? I’m using it in Max 2018 and so far everything seems to work for me, so I’m curious whether I’ve missed something. Also, which version of Max is this where Bercon doesn’t work reliably?
Everything works for me with bercon in IR.
I believe there were at least two recompiles available for Max 2016 or an earlier version and there were issues with either. Now there seems to be one source only (the github repo) and since then I didn’t have any issues.
But I’d really like to hear from those who have problem, maybe it’s not a problem on Corona’s side and something can be done about it outside of Corona if we ask the right people.
pokoy:
Ill have a look at the github and update and see if i still suffer the same issue.
Frood
March 6, 2019, 12:05pm
16
Wait… what version does BerconMaps show for you? (Mapping rollout lower left) And which DLL/Max version is it?
Good Luck
Frood
March 6, 2019, 12:43pm
17
I was asking because this is puzzling, talking about the plugin for Max2016 (which is the 2015 dll actually):
While the version readout in the map itself is always “3.01”,
the version from
http://www.ylilammi.com/2013/09/berconmaps/ (named “3.04”)
and
have the same size but are in fact different at 10 offsets. However we here seem to use the one from github when I compare the hashes and it is working nicely.
Good Luck
I’m on 3.04 for Max 2016-2019 and they work fine.
Looking at my older downloads, it was around the 2013 version with multiple recompiles and d/l sources.
Frood
March 6, 2019, 2:09pm
19
“3.04”? Is it that what you get in the map rollout?
Good Luck
No, the zip’s name. Honestly I’ve looked through every Bercon map and couldn’t find any info on the version. Where do I find this?!
