Corona To Vantage Material Converion Issue
When I export a simple material setup from Corona to Vantage, the material always starts with the Bump map. Because of this, any changes to the material’s texture or color do not reflect in the viewport.
It would be better to include an option to change the material type, similar to what is available in 3ds Max. So I can convert complex material to VrayMlt and create new material. So i do not need to apply material on objects mannually.
Thank you for reporting this. It is now logged for our developers with an internal ID (LAV-3001).
