Hello guys,
I have a problem with the display of colors on my screen. I will try to summarize. So a year ago i bought a monitor (DellU2723QE) and i started to have some problems because there is always a huge diference in what I see in corona VFB and the saved image.
I attached an image were you can see the diference between the vfb and the saved image. I took a photo of my screen with my cellphone because if I took a printscreen the image again displays incorrectly and would show no diferences.
Things I noticed so far: If I open the saved image in Paint it will display correctly just like in VFB. Also the saved image on my right screen (Dell U2715H) displays correctly.
If I open the same image on my cellphone it shows incorrectly just like in my main monitor using windows Photos for example. I also tried diferent formats when saving but it dosen’t work.
I know this has to do with color profiles or something but I tried many things so far. My main monitor is set to sRGB and the right one is RGB (it just shows rgb or YPbPr as color options)
Is there a way to solve this? Have this problem for quite some time now :S
Sorry for the long boring post
Thank you all! ![]()
