My second render, with the same model, but some materials and lights adjustments.
( aluminium look better now ;).
I really appreciate Corona more and more.
Thanks, that’s right, I use IOR 20 for metal, seems to be OK, but I have some problems with glass material, I use solid geometry, but a lot of light is “catched” by the glass, so all geometry behind glass are dark.
I have tried two sided material on 1 face glass objet, but some stranges shadows appears in render.
try 1-sided geometry with thin (twosided) glass. If there are any artifacts, post them here, maybe it’s a bug.
When using solid glass, you get SDS configuration (specular diffuse specular). If you combine that with small light sources/HDRI with bright spots, you cannot render that correctly with any commonly used algorithm. There is however progressive photon mapping in daily versions of corona, which could work
I have made some tests, it seems that the glass twosided thin material cause shading artefacts.
The more I raise the reflection level, the more they are visible.
I have attached an image of renders.
Hm, can you post (simplified) scene? (just glass, frame, the object behind it with artifacts, and the light sources? Either here, or on my mail (keymaster at keymaster.cz)
Hi.
I sent you the simplified scene to your email,
just render from camera009.
The problem is coming from sunlight I think, because, when I turn it off, or lower the intensity to 0.1 / 0.15, artefacts are not visible.
I can get rid off artefacts with sun intensity to 0.15 and glass reflection level to 0.4 up to 0.6.
thanks for your help.
For me, it looks like cheap chinese aluminium. Too smooth and too bright. I would try to make it a bit rough and give it really low glossiness. But I may be wrong!
