CoronaMask - Upgrade
as the “Render Selected” option works, Im guessing this is pretty possible to do.
So the thing is that Im working a lot on product shots, almost mainly. Im often met with this situation where I need to render
X parts of my shot, so in this case take a look at the image.
I will have to create 4 masks for:
  • Small product
  • Product Family
  • Product Family with Shadow/Reflection
  • Product Family as JPG as it is
Ok so just use masks and shut up right? Yeah. no. I will have to create similar sets for 6 products in multiple sets with similar requirements.
So X products times X versions times 4 options, so my request?
Please add “Beauty” cut or BeautyMask option so that would allow us to create this automatically. I created thousands of images so far and this is just part that I can’t automate easy. This would be a good option for some of my future projects where I will have 14 x 16 x 3 +/- 20 (approx 672 renders overall) Doing similar stuff for all of them? Bruh…
Let me know if I understand you correctly:
What you would like to achieve in the end is something like LightMix, but for objects/groups instead of lights?
So you would like to render in one go:
  • full beauty pass
  • another element, where only object A is visible against transparent background
  • another element, where only object B is visible against transparent background
Is that correct?
Pretty much, but just as a separate Render Element where you add objects the same way you would to CoronaMask
but this time coloured, so you don’t have to cut out each set manually.
