CoronaNormal+CoronaMappingRandomizer ignore incorrect gamma warning
if we use the Corona Normal map together with the Corona Mapping Randomizer map with additional outputs, then a situation may arise in which the corona normal map will endlessly issue warnings about the wrong gamma. And even in the case of selecting the “ignore similar” option when you reload the scene, the warning will still appear.
I propose to add an “ignore” checkbox to the interface of the CoronaNormal map itself, next to the field where the warning is displayed, so that this annoying pop-up warning can be removed for selected maps.
In addition, there were cases in my work when I really needed to load a normal map, which was considered by Corona as a map with the wrong gamma, and I had no way to get rid of the warnings.
This looks like a bug, so we will definitely investigate on our end, but could you please provide some more detailed steps how to reproduce this?
