Corrupted EXR
Hi guys,
i am rendering through DR and saving the render through a set path in the VFB rollout.
The EXR saves as pitch black in all the layers!!! :frowning:
If i dont close the VFB and save directly from the VFB, its saves fine.
Whats wrong???
I am still on Vray 1.5 SP5, MAX 2011
Please help!
All the best
now i started havin problems saving from VFB as well…max stops responding an the VFB flashes and disappears and then comes up again and so on…program is not responding :-/
ive checked all my memory settings in BIOS…all setup according to specs
i started bumping to this issue since i enabled color corrections in VFB…i yet have to check this once i get out of all the delay mess that this problem has cost me on rendering deadlines but do you think that could be it?
what i get at the end of rendering is
Apphang B1
performed by 3dsmax…
checked vray log…all went fine apparently…even the save…but the save is pitch black
tried rendering to separate channels…saved OK
may this be cos of the scattering plugs?? Multiscatter and Forest Pack?
