could someone (natty or someone else knows this prob)help me
could someone help me?
:sweat_smile: :sweat_smile: :cry: :cry: :sweat_smile: :sweat_smile:
I have a notebookwith 512 and a pc with 756 MB ram I got on both an unhandled error irrad map thread and the render crash
what can I do to avoid this problem??
the scene has a high number of polygon and reflection/refraction !!
the rendering resolution is 3300x2500
could someone explain how to solve this problem in a simply way!
I don’t understand so well english language
THANKS IN ADVANCE
:cry: :cry: :cry: :cry: :cry:
maybe you can post the error message …
like this, it could really be anything…
paul.
how can I get the exact message now?
I have to relunch the rendering and wait for the error or there is some other technique?
thank for the reply for now
yeah, you can either do that and give a screen Print of your screen…or get vray’s log file and post the last part of it…right before it crashes…i think it’s in C:/vrayLog.txt…or something like that…
paul.
you are probably running out of memory … thats a big image for that small amount of ram.
try to render it in 4 sections, and see if that helps. :wink:
You are deph of field in your scene ?
Vince
error was like this
error was like this:
UNHANDLED EXCEPTION :Irradiance map thread last marker is at P:VladoSVNvrayvraysrcvray.cpp, line 1609: Vray::tracesceneRaystatic()
Ehi Natty alway great suggest!!
But how to do that? (“render it in 4 sections”)
thanks to all I think Natty has focused the problem (memory problem)
hi … its a script called BIGRender 1.0
you can find it here
http://www.scriptspot.com/start.htm :wink:
thank u
thank u natty
I’ll try it :wink: :wink:
natty the helper :lol:
another error message
UNHANDLED EXCEPTION: Irradiance map thread
Last marker is at p:vladoSVNVrayVray.cpp, line 1380: Vray:: trace sceneray static(), calling SDTree::intersectRay()
Please send the fil…
I’m tired to try to solve without success!!
I’m very very scared for the deadline work!!
I hope someone could give me some suggests
bye and thanks in advance
