rendering with contours turned on with a section (as well as vray object section) looks sooooo bad. any work around? ive found i had to render as a layer only and composite in PS (takes more time).
Hello @marquez_colby ,
Conflict between Contours and Clipper is a known issue that has been registered in our internal system as SK-3443. We are working on improving these features in the future.
In V-Ray 6 you can try using Camera Clipping with Contours instead of the Section plane.
ā
