CPU Throttling Down During VRay Rendering (Working on Getting Forum Permissions)
Hey everyone:
I’ve just recently purchased VRay and I’m waiting for my permissions to come through to post in the private sections of this forum.
In the meantime, I figured I’d post up about my issue and see if anyone has a solution.
What’s happening is that when I start rendering, my CPU is throttling up to 100% but then probably 75% of the time it will drop back down almost instantly. When I watch my Task Manager I can tell what’s happening. Essentially, VRay isn’t utilizing all of the RAM that my system has available and it starts using my disk, which slows everything down. The solution has been to go into Render Setup → Settings → System and mess around there by changing the Dynamic Memory Limit and clicking Embree off and back on again.
Eventually, this will work and VRay will use all of the RAM that it needs to keep my CPU at 100% throughout the render (I have 64 GB and I’ve never gotten about the 50% mark while rendering). The confusing part is that I can finish that rendering, click render on a new one in the same file without changing any settings, and it will throttle down again as it did before. The only solution is, again, to fiddle with the Dynamic Memory and restart the render a few times until it works.
I’ve tried setting the limit to 0 so that it uses what it needs and I’ve also tried setting it very high (48000, 50000, or 64000) and none of them work consistently. Any ideas as to what the problem is?
Thanks in advance for any help you can offer!
What cpu ? Also, progressive or buckets?
It’s a 6900k. And it’s set on Buckets currently. I’ll have to double check to see if it does the same thing on Progressive.
No help then, sorry. I’ve had problems with progressive not using 100 percent cpu.
No problem, thanks for the effort. I suppose I’m lucky that it will throttle all the way up from time to time! It’s just puzzling that you can restart the same render with no changes to the settings and it will act differently.
My biggest fear, and something I haven’t tried yet, is that I’ll set the PC to batch render a bunch of finish renders overnight and it will render the first at full power but then start throttling on the subsequent ones. That and it’s just a pain to stop and start to get it to work! I’m sure there is some solution and hopefully we can get it solved on here fairly soon! Probably have more community help once I get access to the “Problems” forum.
