Hi Forum,
Just had a request to do a book store virtual tour. It’s a basic point n click, then look around at the selected points. I read that you can now do this with Chaos/Corona. Can this be outputed as a stand alone project I can send to the client or is it a login thing? They need it for a conference so guessing it needs to be standalone? Never done one before but understand how it works. Any advice and guidance would be super helful, thanks
JS
It’s wayyyyy simpler than that - no login, no standalone, no installing. You just send them a URL, and it opens in the browser.
https://youtu.be/NlvJ29OKdz4?si=vCUP7hHFEhQmAE-S&t=803 covers it (though the previous section covers sharing options, as you can limit sharing to specific email addresses or require a password I believe, with the last one being new as of a few days ago so I don’t have details
Tom,
This is super interesting as I was outsoursing my virtual hotspot tours, will give this a go… I assume it works similar to 3DVista? Many thanks, John
Sorry I’m not familiar with 3D Vista specifically, but I can say it works similar to other virtual tour solutions in general, including ones I have used. In many ways better, given you can get renders straight to it from the VFB, it doesn’t need some server or space set up to store everything, can autogenerate hotspots, handles VR, allows for comments for conversations back and forth between you and the client (or turn those off once it is a final deliverable that your client will share with their customers), and it’s still improving e.g. recently they added support for multiple floor plans in one tour, password options, and more!
Let us know what you think when you’ve tried it out! And for suggestions or feature requests, feel free to post on the Chaos Cloud Ideas Portal at https://chaoscloud.ideas.aha.io/ so that it goes straight to the team responsible
Tom, HOLY S!!! Just tried it out with acouple of rough renders… This is so simple to use and will be a good tool to offer to clients. Thank you and have a great weekend
Great you tried it out, and great it fits your needs
Thank you for the feedback (and I’ll pass it along to the Cloud team). Enjoy using the Virtual Tours, and keep an eye on things coming from the Cloud team as there is more to come this year. Cheers!
Hi Tom,
Got a couple of questions, let me know if i’m posting it in the wrong place!
- My renders are facing the wrong way, backwards. How do I set them to face forward?
- How do I label hotspots to change over the whole tour? Have changed one view but then have to do this to every view, very time consuming.
Many thanks, John
Check each image, there are options for how the view is displayed, including “camera default” or “which direction you walked here from”. If the “camera default” is backward from what you expect, rotate the camera (180 degrees by the sound of it) in the scene to re-render, or there may be some option to set a fixed direction among the camera default and direction you walked here from settings. I usually go with “the direction you walked here from” since that makes sense from the perspective of walking around through the scene
And then it doesn’t matter what camera orientation was used in the scene (except for the first image that starts the virtual tour)
Labeling hotspots for automatic hotspot generation can be done by labeling the image filenames, so an image for the living room called “Living Room” will cause its hotspot to be called “Living Room” by default. I generally rename the images prior to uploading them (click the image name in the “upload to collaboration” dialog in the VFB), or you can rename the images once they are uploaded then re-run autohotspots and all connections to the living room image will be renamed “Living Room” (easier than editing each hotspot manually after doing the autohotspot generation).
Let me know if that answers the questions!
Hi Tom,
Thank you for such a swift reply :-). I sent an invite to a friend to test, apparently he needs login details? Is this right? Do I give him my Chaos Cloud logins? Also, can I render all 18 cameras in one take or do I need to do them individually? This is my last questions! Thanks again, John
