I have successfully set up distributed rendering using XP/Vista/Xin7. Now I am trying to add an OSX machine into the mix! It renders fine but it can’t share the textures as the path is different when you mount a share on OSX and it tells me that it can’t load the bitmaps from drive s:/…
You can use the environment variable VRAY_ASSETS_PATH to specify the location of the textures; set this variable before running the V-Ray render server and V-Ray will look there for textures that it cannot find.
