I am trying to render material with houdini and material style sheets (because the character are done with multiple parts) I can see the material assign in the viewport but it is not visible during the render!
what is the specific workflow for that? No help anywhere on google.
Thank you for your feedback!
Sebastien
We dropped support for stylesheets very long time ago.
and any solutions? How can add different material for differents agent with different shaders.. (cloth, skin, pants…)
Geometry attributes + Mtl Multi / Tex Multi / Tex Pattern.
That’s “chinese” for me but I will try to understand, sorry , I can imagine you add already explain that a toushound of time…I am importing directly fbx as agent..
thank you for your help.
Have a great weekend
Hi @sbastien_levieux ,
MtlMulti is a material container which will assign materials based on materialID. The materialID itself is generated by TexPattern based on a string attribute match. This is an example of Crag were the materials are assigned based on s@pattern.
MtlMulti_TexPattern_example.zip (43.7 KB)
Thank you for your time and help, I will try it,
Happy weekend for you.
not working for me, the agent is packed and during the render I don’t have the differents part. I can’t set it up with that FBX as agent: https://drive.google.com/file/d/1IWlVoGMMJPQudEuY4wWvMfYmtulJQzLp/view?usp=drive\_link
Just pack your character using the name attrib and transfer the attrib as well and then do the same
Thank you for sharing your set-up, @sbastien_levieux
Do you have an idea for randomness biptamp texturing and crowd with vray?
