CScatter - Density parameter weird behavior
As in the title, CScatter - Density parameter has a “weird” behavior.
I know that it defines the instances based on Density per unit area. But:
() Create a plane 10x10 cm
) Create a teapot 0.3 cm as radius
() Create a CScatter with Density (not Count) as a distributor.
) Displayed [%]= 100
(*) You can play with Density, without problem, in the range between 0 and 50.
Perfect. Now try now this:
() Create a plane 10.000x10.000
) Create a teapot 300 cm as radius
() Create a CScatter with Density (not count) as a distribution
(*) Density is impossible to use, because with Density=0.001 we have already too much instanced. The range is too small.
I think that we need some “Density multiplier”. Because, as it is now, it useful only with tiny objects
Bye bye!
~~Duplicate: Renderer for architectural visualization - Corona | Chaos
Edit: oh crap, i thought it’s posted in bug reporting board :]
It’s not a bug in the density parameter.
It works. But, when we have a big surfaces, it’s useless.
EDIT: Ondra confirmed: it’s a bug.
