I like to use a curvature in a node material, but don’t know how to get a bitmap into the sample spread slot.
Could this be a mistake, or am I doing something wrong?
Node texture curvature
Here the classic..
Using Win11 R26.15 latest available nightly Vray5 build
Hey @haniel1107 , the parameter is just not shown in the node view, but it is there and can be connected. You can explicitly show it with the right click context menu, or you can just connect the texture and select the exact port you are connecting to.
You can also directly select an existing bitmap node if you click the circle for port input in the attribute manager:
Hi @deyan.hadzhiev , great thank you..!!! This helps a lot!
I think I should try sometime the right mouse click
Hi @YunalZobu , this is of course also cool… didn’t know this… THANKS!
