I have searched through the internet, there is absolutely no information on how to output DeepEXR with Vray3.0 in Maya. The old method was to use some phython scripts to output a VRST file, but OpenEXR2.0 has since replaced it. 3dsmax has a simple way to output deep data, just a few clicks will do. But none in Maya 2015?
Can someone enlighten me?
You can’t regulate the exr output format directly in VRayStandalone or in batch render.
But you can directly export the .vrscene file with the option to save to (deep) EXR. Or you can open the .vrscene file in a text editor and set the “img_deepFile” flag in the SettingsOutput plugin to 1.
So if i export the .vrscene WITHOUT the option to save to deep EXR (because VrayC4D does not have that option), then can i still render a deep EXR by opening the .vrscene in Notepad and just set the “img_deepFile” flag in the SettingsOutput plugin to 1?
This version is too old and I don’t think that it will support Deep EXR.
It would be better to install the latest demo version of V-Ray for Maya 3.x which comes with V-Ray Standalone demo 3.x version which supports Deep EXR files.
It looks like it does. The SettingsOutput plugin has a parameter “img_deepFile” which must be set to true when writing .exr files in order to produce a deep exr.
Please disregard my previous post.
Like Vlado pointed out version 2.25.01 supports Deep EXRs.
Currently we do not have a separate installer for V-Ray Standalone 3.x demo.
You have to install either V-Ray for Maya or V-Ray for 3dsMax 3.0 demo version - they both comes with V-Ray Standalone 3.x demo.
