I would appreciate a Corona function to delete identical Corona materials, not based on the material name but rather on settings.
Submitted on AHA Ideas (CC4D-I-30).
in addition to this, combining duplicate CoronaBitmaps into one would be great - assuming all settings like tiling, filtering etc. are the same
Submitted on AHA Ideas by Sam Large.
Prevent and Manage Duplicate Materials in Corona (Cosmos, 3ds Max, Cinema 4D)
Description:
Currently, Corona creates duplicate materials in several workflows:
This leads to unnecessary clutter, harder material management, and slower workflows in larger scenes.
Suggestion:
Please add tools or options to help manage this:
This would keep scenes cleaner, improve organization, and save a lot of time for artists working with large projects.
Submitted on AHA Ideas by Patrice Siebenaler.
Description:
Suggestion:
Does this refer to redundant maps (specifically CoronaMappingRandomizer and CoronaTriplanar) from Cosmos imports, exactly?
There were improvements in this regards and now additional outputs of the same CoronaMappingRandomizer and CoronaTriplanar are used instead of creating new maps with identical settings.
If this refers to multiple different, but with identical settings, materials created and plugged to different multi/sub-object IDs, then this is reported and will be fixed:
https://jira-chaos.atlassian.net/browse/CMAX-2010
If this refers to the case as below:
Then I am not sure what is the best way to handle this - there may be cases where you would like to use the existing material, and there can be cases that you want the new one created. 3ds Max has material duplication warning when merging objects, which is not triggered for Cosmos imports. Would you expect it to be triggered? Not sure how this is handled on C4D side.
Submitted on AHA Ideas by Аram Аvetisyan.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
