Denoiser for render elements?
Is there a way to utilize denoiser for render elements yet? My reflection and specular passes have a ton of noise when I go to composite them. Or is the only solution still to bump up the render samples?
Pretty sure there’s an option to enable denoising on each render element. If not you can denoise individual passes with the standalone denoiser
Yep, it is there for each render element
You guy’s are totally right. I can’t believe I never noticed the checkbox at the very bottom. Thank you!
