Denoiser + Lens Effects
After hotfix 1 denoiser and lens effect “EffectsResult” element isn’t blending.
Happens with pre enable and default settings.
Happening on all SketchUp models.
Is this a known issue?
Could you please provide screenshots to illustrate the issue and the settings used?
In the meantime, you could lower the Threshold parameter and see if this produces the desired effects
Thanks Georgi,
The issue persists. Even when starting a new model, when using V-Ray Denoiser no lens effects can be applied.
This was happening right after hotfix1 and I couldn’t revert to the initial build due to the warning message implying things was made in a newer version, so I’ve sticked with the hotfix1 hoping for a resolution.
Glare element is black. Effect result doesn’t apply lens effects.
Would it be alright if you send us an sample project to further investigate?
Hello, Moshe,
Could you please toggle off the Lens Effects panel’s “Load filter” and “Use Obstacle Image” checkboxes and see if this resolves the issue?
Kind regards,
Peter
Thanks Peter I was able to regain control over the lens effects however it doesn’t seems to be using the denoiser element. I’ll try to work this out again and have you informed.
Success, all is good, it was the “Load filter” checked. Thank you!
