Depth of field issues with reflections
Hi all. I got an issue with highly reflective objects in foreground while using physical Corona DOF. The top of the foreground objects are still in focus which in real life camera will blur them according to a focal distance. Any suggestions?
Are you sure? :wink:
Take a mirror and put it reeeaaally close to your eye. Do you see the reflected objects far away blurred or sharp?
About noise: please show your render settings. What kind of lights are you using?
it does not matter - the eye will blur it because it will be out of focus- eye could not have in focus FG and BG at the same time. and camera as well. But thanks for lightening this. For example if you use dof in post instead - the dof will be right. Strange thing. The fake dof is more realistic than the real one.
I wrote that to encourage you to check it yourself in real life. But below you will find a picture I have taken myself a minute ago, the string is just for reference - it IS out of focus so the mirror is out of focus too. Only “bg” is in focus. :smiley:
My argument in such cases is always the same - without it you would be unable to see anything when using SLRs or periscopes. They have a mirror inside, and it is very close to your eye, right? Or you can also imagine that every flat mirror is like a hole, in which you see flipped reality. :smiley:
Conclusion: Corona’s DoF is real, fake DoF is fake.
And if you don’t believe in pictures i recorded a video :]
:smiley:
looks and works exactly like something filmed through a window
this thread should be linked every time a question like this appears (and I’m not complaining! I understand that this is counter-intuitive!)
Thanks Folks, it is really true. I have had no doubts in it. But the thing is - it LOOKS unreal. And after making an experiment with the mirror close to my eye and having the focus on background the reflections on the mirror Are blurred. So here is difference between the camera and the real human eye vision.
it’s looks real)
Just stop fantasizing about it and start to look on it)
I’d suggest visiting an oculist.
Thanks, Maru. I will definitely follow your helpful advice.
Just a confirmation for those who like me needs an oculist visit. Those whos got a perfect vision please ignore my post
In your first example reflection is blurry more due to rough surface of pavement than DOF. You can see this if you compare vertical and horizontal features in girl’s reflection - see how horizontal lines are blurred much more than vertical ones? Also look at the man’s in background head reflection. It lies in focus area, but is very blurry.
And in the second picture these are (neraly-)spherical reflections. They work completely different.
I hope I have some authority in rendering, so I would like to end this debate by saying that this video is correct ;).
Yes, you can focus on something in mirror without focusing on the mirror itself. If it were not possible, DLSR would not work, as you are observing the scene in viewfinder through a tiny mirror in front of the sensor.
And in the second picture these are (nearly-)spherical reflections. They work completely different.
This is what I am trying to figure out. Sorry if I sounded like a dumb. Thanks a lot for your help as it has cleared a lot of my dark patches. I do my apologies guys for taking your time.
Dude, no problem! None of us is all-knowing! This forum taught me A LOT of things. For example, that sun doesn’t get bigger as it sets down (which is kind of sad and kills some magic).
