Differences between academic and regular Vray
Hi All, I am going back to school soon and I would like to buy Vray. What are the differences between academic and regular version? I know that the price is one, is there any limitations with academic besides that you can not use it for commercial use (make money off it)?
Re: Differences between academic and regular Vray
:wink: Found the answer :wink:
for the sake of anyone else out there that has the same question, you can’t use the academic version for commercial work, and the price is discounted for students as well. Those are the only two differences between the commercial and academic versions.
Resolution output?
shouldn’t be limited in the academic version.
Resolution output?
heheheheheh thsi was so funny…you are a patient man Dkending…hehehe so funny!
in the past we did limit the output resolution, but if the resolution is limited, it’s really hard to make renders for some presentations or projects in school. We ended up taking the resolution limitation out in… 1.05.30? It’s definitely not there in 1.48.66 or later, I know that much for sure.
I actually like these kinds of questions, you know, the ones I can answer without having to write code :wink: I dread the ones like “why doesn’t this scene work?”, the answer usually results in me having to do a lot of work ::cries::
