Hello
A very small niggle, but why isn’t diffuse or colour map one of the default exposed connections in a Vray Mtl in Maya ?
cheers
ben
When Autodesk introduced the new editor, we couldn’t find a way to make this exposed, since Maya would refuse to read our color attribute. So far we haven’t found a way to work around this, sorry for the inconvenience.
Thanks for the explanation .. hopefully it gets ironed out as Autodesk update Maya.
We can only hope ![]()
You can still use the ctrl+mmb-drag and it will make the default connection, which is the diffuse channel.
