I’ve just setup light mix. The scene only has 3 lights. I’ve not adjusted any setttings yet in lightmix, just separated out the lights. But there is a difference between the beauty pass and the light mix pass. The shadows are lighter in the lightmix pass. I’m just waiting for the render to finish and will upload comparision shots when it’s done, but just wondered if anyone had experienced the same thing.
But if my settings are as shown in the screenshot and those are the only 3 lights in the scene then it should look identical to the beauty right?
there are other lights in the scene but everything is turned off. I turned ‘Rest’ off anyway just incase it was picking up any of the other lights that were turned off.
I always found this to be the case as well, although very minor, so I never really even bothered to do PS overlay to check. I thought it’s byproduct of some order-of-operation or layering method, etc..
Yeh it’s more obvious when you view the whole image, but I think even that crop is signifcant enough. If its perceptible just from switching from Light Mix to Beauty in the frame buffer then it needs fixing imo
After discussing this issue with our devs, it seems like they are aware about this issue, and it is currently logged in our system. It is currently being investigated. According to our devs, this can rarely happen when user uses UHD or 4K cache.
We will let you know if there are any updates on this."
Would have been good to know that before I spent half a day sorting the scene out ready for upload then waiting ages for the 6GB file to actually upload
I have no idea what part of the scene is causing it. Also I had a previous message from support saying they can’t even open the scene because it crashes despite me having no issues at all opening it at my end. So it seems it was indeed a waste of time.
If it crashes for us opening it, definitely not a waste of time, as we’ll be looking to fix that crash too as a bonus extra. TBH sending in a scene always helps, so is never time wasted. And we do appreciate you taking the time to do that!
