Hi all
I’m having a few issues when switching on the dispersion.
The pipe on the left is polycarbonate from the library.
The middle pipe has practically the same settings as the polycarbonate with the addition of some depth on the translucency - to achieve a plastic look with some white areas depending on thickness (Please see attached).
The right pipe is identical to the middle pipe but with Dispersion switched on set to 50.
For some reason adding the Dispersion floods the whole pipe with an almost opaque look..
Cheers
Steve
