Dispersion?
I see with the new release of Vray for Rhino 4.0 it is now possible to have dispersive materials. How do I make one to make a diamond look real? or other gems for that matter?
Re: Dispersion?
Thats from this thread here
A quick addition to the comments above; the amount of separation of each of those colors is going to depend on the amount of change in the IOR of each of the refraction layers. If you would like a wider dispersion effect, but not as much break between the colors you can try a version with 6 colors in the transparency slot rather than 3. Those three additional colors are 255,255,0 (yellow); 255,0,255 (magenta); 0,255,255 (cyan). Hope this helps.
Re: Dispersion?
Just to clarify where those colors are coming from - they are the white-complement of the colors of Red- Green- Blue. To calculate the white-complement you simply subtract the color from white. So…
White = RGB(255, 255, 255 )
Red = RGB(255, 0, 0 )
Red_White_Comp = White - Red
= RGB(255, 255, 255 ) - RGB(255, 0, 0 )
= RGB(0, 255, 255 )
