Hi all,
I’m getting some weird artifacts when using displacement in Vray 5 for Maya 2020 - I’m attaching what I’m seeing as well as the test file.
Can someone please take a look and tell me what’s going wrong here?
Thanks,
Matt
If you reduce the edge length on the vrayDisplacement_cave_01_hole to 0.2, and encrease Max subdivs to 16, this seems to reduce the effect you’re getting.
That appears to have worked!
Thank you, stezza!
Without looking at your file, this type of thing can usually also be fixed by just smoothing/subdividing your geo as well. It’s simply a tessellation issue so you can address it with the displacement attrs. or by adding more resolution to the mesh.
