Displacement is driving me nuts...
I am really struggling with displacement and I would love some help. My rendering shows my material but no displacement and I can’t figure out why. When I add my greyscale image and set my multiplyer to 1, press my update button, I can see displacement. But when I render…it just shows my image with no displacement. I will tell you what I did step by step.
Applied texture to object in SU
Linked material to V-ray
Under maps I checked displacement and pressed M
Selected Bitmap in rollout and applied a grey scale version of the image
updated material to see what it looked like and saw displacement
Rendered…no displacement.
I would be greatfull for some imput. Thank you.
Re: Displacement is driving me nuts…
Oh yeah…my greyscale image was done by desaturating my original in photoshop. I’m not sure if this is correct?
I tried applying the material in SU and linking it to vray and I tried applying the material directly into v-ray…if you know what a mean.
the surface that you want to displace you need to make it grroup in skp, and then render, hope it helps.
I will try that. Thank you
Hello.
I did have the same problems before with displacements then I asked this forum for some guidelines. I followed it and it worked. Here it is:
1. Create model or plane/surface
2. Apply image texture on surface/model
3. SCALE in SketchUp image texture on surface/model (this is important)
4. Group model
5. VRay material editor > material link
6. Set material settings in VRay (Diffuse, reflections, etc…)
7. Apply displacement map in the Diffuse > maps tab
8. VRay options editor > load options > displacement (set to 2, 500, 1)
9. Render
Hope this helps!
zun_kian
guys theres a carpet vismat made by nomer available at the download section. :wink:
