One more issue. I’m trying to create a material with 2d displacement for fast 3d grass rendering (among other things). I add a displacement bitmap to a generic material. Then specify a bitmap and set the mode to 2D (UV Channel). But it always sizes the bitmap 1 unit by 1 unit, even if I specify 5x5 in the appearance manager. If I turn displacement off and put the same bitmap in the diffuse or bump slot, then it maps 5x5 correctly. Much searching has found no solution.
Wayne
Wayne,
I’m unable to reproduce this. Do you mean that
1. the preview of the texture does not change when you tweak the transforms in the Appearance Manager
or 2. it does not update on the rendering?
If you render, do you render on CPU or GPU? Because 2D displacement is supported on CPU.
Ana
Hi Wayne,
We will have a look at this as it seems like a bug.
As you mentioned that you’re using displacement for the grass, why don’t you try out V-Ray Grass/Fur? If you share with me what exactly you’re trying to achieve, I can be more specific.
Best,
Ana
Thanks Ana. Vray fur is much too slow to render when there’s large areas and/or when it’s far enough away that you can’t tell the difference. I’ll use it sparingly for small amounts of grass close to the camera. Also I use displacement for many other things, it’s one of my favorite features.
Wayne
Be careful not to overdo the displacement, as just like grass/fur it is meant to add detail to the image, i.e. use it in the foreground the way you use grass. And use bump for the remote objects.
In case you end up applying grass/fur to a large area, use the Level of Detail parameter.
I didn’t know about that parameter, that’s good to know. Were you able to import that test vrmat file from 3dsmax into revit? Wondering if that’s a bug or if it’s only happening on my end.
