Hi guys,
Figuring out how to deal with these settings and I could notice that the value of 2 is a good balance but still leaves some artifacts. What is the drawback in lowering this number? longer renders times, memory?
Also, what is the World Size option for?
Does Corona have any documentation files? I couldn’t find it on Chaos’ website.
For the render settings: https://support.chaos.com/hc/en-us/articles/4528597846673-Render-settings-explained-Corona-Renderer-for-C4D
The Help Center: https://support.chaos.com/hc/en-us/sections/4526265417105-Corona
In general, smaller settings for displacement will render longer and use more RAM. World size defines the actual size limit of displacement details in “real world units”, while Screen size is relative to the extension of a detail on the screen (in pixels). For animations, World size might be better, because the chances it will flicker are less likely (because your geometry keeps its dimension in mm no matter how far away, unless you animate it, of course, while the pixel size of a detail varies with zooming, for example).
HTH a bit,
Michael
