Displacement....? urgent!
Now i m getting confused!
so i got an editable poly with 3 faces, all quads…and the 3d displacement is going wacky!?
what am i doing wrong?
the wireframe:
the displacement under 2d mode:
the wacky 3d displacment:
and even if i change the mesh the wackiness continues!
please can anybody give me any hint?i ll take anything!
yeas and i ve read the morbid angel s thread!
:sweat_smile:
post your file and I’ll have a look.
the fastest way i could remember to post the file
:sweat_smile:
thanx in advance!
Why are you trying to displace the mesh 10cm for mortar joints?
Its weird, I’ve rendered it a few times and it looks fine to me. I can’t see any of the distortions you have illustrated above.
actually, i do get distortion with 3dmapping at 10cm amount. But that would probably be expected given the scale of the mesh.
Either
- reduce the displacement amount
- change to 2d mapping
- if you stick with 3d mapping(and 10 amount). Increase the number of quads making up the surface
oh, and reducing edge-length to 1.0 seems to work a treat on 3d mapping.
i thought i read 3d mapping was mainly for 3d textures like procedural noises…
I generally always use 2 displacement for mapped textures…
Lele
thanx re:FORM i just got to the office…ur probably right.
in fact i just tried the 10 cm cause i expected it to be more vivsible instead maybe i m just screwing it up…? i m gonna run some tests right now.
yeah Lele i usually stick with 2d, still i need to use the keep continuity option, so i was messing with 3d displacement. i got away tonight at home to fix this with an old trick… :smile:
thanks again! :wink:
