Hi all
So I have a strange issue on a new machine.
Quite simply, displacement will not render. Render times go from a few seconds to 30minutes plus on my machine. On other machines, same spec, it renders as expected.
I tried as a test going back to Vray 3.2 and it renders as expected. My machine is Xeon E5-2699 v3 dual processor, 128 gigs of ram. The only difference between my machine and one that renders fine is the gfx card. I have a 970GTX and the other has a K6000 Quadro. I know I had to install a different chipset driver so I’m wondering if this and Embree has some kind of issue and it can’t render displacement. Everything else renders fine.
As a side note, I also can not render in unity on this machine, it crashes out instantly but leaves a note in the log about Embree which is why I feel it is an Embree issue.
Any help on this would be massively appreciated. I’ve spent a ton on this machine and its not working as hoped currently.
Cheers for reading.
Will.
