display tag
Hello!!! the c4d “display tag”, with opcity animable, doesn’t seems to work with corona… is it a way to progressively make objects appear or desappear???
Animate the Opacity in the Corona Material itself would be one way. You could also render with and without the object and blend in post (opacity method inside the software will show backfaces etc. which may be undesirable depending on your needs).
Thank you, Tom! I have seen precedent topics (I know, better is to begin searching!), and opacity , as I have an object desappearing and one another appearing, do perfectly the job!..
