I’ve encounter an annoying problem when DR is on, see attachment please.
This image is only lighted with a VRay Sun + VRay Sky to make it clearly visible. But it can also be reproduce with a HDRI plugged in a VRayDome but it’s more subtle…
Workstation : Windows 7 Pro x64, Maya 2014, VRay 2.4, plug-ins: only VRayScatter v4.0.3
4 x RenderSlaves : Windows 7 Pro x64, VRay 2.4 Standalone, plug-ins: only VRayScatter v4.0.3
I have just formatted all my RenderSlaves in order to solve this problem but it still here. Before the formating, Maya 2014 was installed on them with VRay 2.4 for Maya.
Sometime it happens, sometime everything is fine even if I relaunch or not the VRay Spawner on each slave or completely restart them…
It’s really happening randomly and I have to wait untill the rendering of the image (because during the calculation of the IR, everything seems fine).
Could it be related to the resolution of the rendering size (7000px wide)?
I also tried to reset the IR map already stored, sometimes it’s working, sometimes not.
If you have an idea about what produce this bug it would be great!
Regards.
The issue in the other thread is that the environment map was not available on the other machines. You can disable it to do a very quick test if this is the same issue. With VRay 2.4 the only way is to make sure all maps are available and the same. The nightlies are able to transfer assets and abort if something is missing.
I am aware about the steps to follow that solved this previous topic and I did it but the problem is still here…
And as I mentioned I’m only using a Vray Sun + Vray Sky so I don’t know how my Render Slaves could not be able to reach it throught my network…
I’m on Vray for Maya v 2.40.1 but just can’t find the nightlies version you talk about.
Where can I find them please?
Regarding the issue with the different bucket brightness you have encountered, please provide more details about the workflow that you are using. It looks like a GI issue.
As Stezza mentioned above, do you use precalculated GI maps?
Does it render correct with DR when GI is disabled?
You could check the GI render element if its added to the scene.
Also could be a gamma display issue. I’m not sure if maya has gamma or LUT correction, but it looks like some of the machines might be displaying 2.2 gamma. Just food for thought.
I know this doesn’t apply to your scene, it’s really aimed at anyone else who stumbles here with the dreaded squares-on-the-render problem…but one thing i discovered was not having my ies light profiles in the source images folder meant that the assets were not transferred. I thought they were being picked up by the other machines but they weren’t, which caused different coloured DR buckets.
