Hi all.
We’re having a problem with DR when rendering from a VrayCam.
If I render the scene with with DR turned off OR from a perspective view everything renders fine. With DR turned on the Light Cache and Irradiance Map don’t work and the frame buffer is just black.
Even more weird - if I make a new VrayCam and use DR it is fine.
At the moment we’re not sure if the cameras were set up before upgrading to Vray 3.00.02 from 2.4.
Has anyone else seen this or can anyone reproduce this?
Thanks in advance.
