Does not render invidual frame #
I am rendering still images, not animations. I often change the position of the sun between different camera views. For instance I render Frame 0 for late morning sun position. Then I move the time slider to Frame 10 and key frame a new “afternoon” position for the sun. I render Frame 10 with sun moved to afternoon position.
In the past, using chaos cloud with 3DS MAX 2023, if I had the time slider at Frame 10 and submitted the job to chaos cloud it would render with the sun in the position set at at Frame 10.
Now when I do this in Chaos Cloud, no matter what try, it is always rendering with sun in Frame 0 position.
Also, before submitting to Chaos Cloud I us the Cloud “Preview” and that renders with the correct Frame 10 sun position. But, as stated, when I submit the job to Chaos Cloud it renders as sun at Frame 0 position.
It seems Chaos Cloud, suddenly, will not and does not render an individual frame correctly.
What am I doing wrong? Please help, I need help ASAP.
Thank you.
Here are two screen grabs showing what I mean.
Hi @OPEN_RANGE
You can set frame 10 to render from the Render Setup > Common tab > Frames for the time being. We’ll have a look and see if we can make sure to take the time slide into account when submitting jobs to Cloud - thanks for raising the flag! Will let you know as soon as there is an update on the matter.
Thank you Nikoleta. Please do let me know when this has been updated. Thanks!
We’ve fixed the issue and builds are updated - you can download them directly from here.
Wow. Fastest fix ever! Thank you and especially thanks for following up with notice of the fix.
