I can’t use the camera properly as i was doing with the old version.
I understand, that if i want to be able to change the exposure from the buffer, i need to DON T apply the corona camera mod, but if i do that, i can’t control the DOF as before.
Another very useful and amazing thing about Corona, was the ability to control the DOF intensity, being able to fake a focal lenght, and then change the F values.
I can’t find this option anymore…i feel lost!
But where I can find the sensor size option with the new version?
Edit: ok, got it, so basically if i want to be able to control the DOF, I need to activate the DOF in the render settings (before i was doing from the camera modifier) , and if I want at the same time to control the exposure during the render, I will need to activate Photographic exposure.
Basically, I don’t need to use a corona camera modifier on the vray cam anymore…is that correct?
I wouldn’t recomend to use sensor size for DOF control. Use F-stop spinner instead.
Yes, you have to enable DOF in render settings in order to render it and no, you are not forced to use photographic exposure if you don’t want to. You can use arbitrary exposure control via EV spinner and have control over DOF at the same time.
And CoronaCamMod isn’t necessary for all this as it wasn’t required in previous versions too.
Hi. If you’re using v1 and follows the description from Rommulus last post, then it should show in the IR. Don’t use Max’s DOF and f-stop settings in the Camera. Use the settings in the Render Setup, scene tab (or use a Corona CamMod).
But how do you change the F number being able to use free exposure?
THe only place where i can see the F number settings, is under photographic exposition, but i don’t want to use it!
Just to clear things up: It is actually possible to use “free” exposure and f-stop setting. You don’t have to activate “photographic exposure” to use the “f-stop” settings - even though it is placed in that box. As long as it isn’t greyed out, it’s active.
Although the usage is clear to me personally, one thing that bugs me a lot as a photographer is that the default ‘sensor width’ is set to 35mm…
35mm film (or full-frame digital) size is actually 36mm x 24mm - that’s 36mm wide, not 35.
I just notice a little “bug” in the DOF system, if you see the reflections on my cabinet, show the chair and table out of focus, but actually, that plane is on focus, so, the reflections shouldn’t be out of focus.
The easiest example to imagine for me is when you are looking into a viewfinder of a DSLR - the mirror is very close to your eye, yet you see a sharp image. Or you can just use some ordinary mirror. If you place non-reflective object close to your eye, it would get blurry.
It is correct. Imagine a mirror surface as being a ‘window’ that extends to your reflected objects. That creates distance, which is now out of focus.
As for the ‘35mm’ defaults - width-wise the number is incorrect and should be 36mm. I’d expect to punch in 36mm width if I was matching a rendering to a photograph/video from my EOS 5D Mark III (or 22.2mm for EOS 60D) just like a cinema professional would expect to punch in 70mm width to simulate an IMAX frame.
It says ‘frame WIDTH’, not ‘film standard’, in which case 35mm could mean Cinema 35mm standard (3-perf), which is actually only 24.9mm wide!
That is confusing right there!
Which brings me to another question… Does the current DoF scale measure correct for 36mm (36mm in the setting calculates 36mm) width or is the default 35mm actually calculated as 36mm?
yes, it should be 36. Corona uses that number directly (well.. converts it to scene units first). So by default it uses 36mm. There are some approximations involved in the model of ideal thin lens camera, so I dont know how well it matches real camera DOF (if the ~3% difference is not actually lower than some other error produced here)
