What I’m trying to do
Transitioning from Enscape to V-Ray for our product 3D visualisations. We use a custom-made skybox: a cube map in cross format (six square faces). To understand how V-Ray handles it I made a test HDRI (see screenshot below):
It worked in Enscape, where you load it and turn a single rotation slider. I rebuilt it for V-Ray as a vertical cross, loaded it into a Dome Light with Mapping set to Cubic, and it renders correctly.
All I need now is to be able to rotate it horizontally if necessary.
What happens
With Mapping set to Cubic, the only rotation control in the texture settings is Rotate under 2D Transformation:
So I used it. At 15°, the mapping was completely broken: cube edges bent into curves, faces sampled from the wrong parts of the image:
I assumed it was a bug in Cubic mapping and spent a good while testing before working out what was going on:
- The 2D Rotate spins the flat image itself before it’s mapped. It’s the wrong control for an environment, but nothing in the UI tells you that.
- The correct control, Rotate H, is only shown when Mapping is set to Spherical. With Cubic, it’s hidden.
- Rotate H does work with Cubic. If I set it in Spherical mode and switch to Cubic, the hidden value is still applied and rotates the cube map correctly.
- After switching from Spherical to Cubic, the panel stops showing Rotate H altogether, which made it even harder to understand what’s going on.
Why this is a UX problem
For a Cubic environment, the UI hides the control that works and shows the one that breaks the mapping. Any user trying to rotate a cube map will end up exactly where I did. On top of that, a hidden value silently changes the render, with no way to see or reset it in Cubic mode.
What I’d expect
- Rotate H (and Rotate V) visible for Cubic mapping, the same as for Spherical, since the renderer already supports it.
- With Type set to Environment, the 2D Transformation Rotate either hidden or clearly labeled as rotating the image itself, so it can’t be mistaken for rotating the environment.
- No hidden parameter affecting the render.
Steps to reproduce
- Add a Dome Light and load a vertical cross cube map as a Bitmap.
- Texture Placement: Type = Environment, Mapping = Cubic. Note the only rotation control is under 2D Transformation.
- Set that 2D Rotate to 15° and render > mapping is distorted.
- Reset it to 0. Switch Mapping to Spherical, set Rotate H = 90°, switch back to Cubic, and reopen the Asset Editor > Rotate H is no longer visible.
- Render > the cube map is rotated 90° and mapped correctly.
Current workaround
Enable Use Transform on the Dome Light and rotate the widget in the viewport.
Not ideal, because when setting up the HDRI, we now have to constantly switch between SketchUp viewport and V-Ray settings to adjust settings.
System
- Windows 11
- SketchUp 2024
- V-Ray 7
- Render engine: Intel Core Ultra 9 285K, NVIDIA RTX5090
Test HDRI.zip (80.7 KB)
