We are actually working with multiparts EXR, so our beauty can grow up, with ~20 render elements, to +200 Mo each frame.
So the lighting team is loosing time by loading in RAM every sequence in PDPlayer.
It could be nice to have a double output :
- 1 EXR multipart with all render elements
- 1 jpeg (or whatever) only of the Beauty, just to check if the render is fine.
Or we also save an 32b deep output while we are rendering a 16b multipart beauty.
All the informations are in the Vray Frame Buffer, so why can’t we save multiple formats ?
You have the max standard output, the render channels output and/or the raw image output. All 3 of them can be switched on. For stills I use all 3 of them. jpg for the beauty with max dialog and output channels in .tga. And a vrimg as a raw so we can have some finetuning in the VFB first if needed.
So I’m not sure if I understand correctly but this is already possible.
- 3ds max output : indeed, this could work. It would just not allow the ‘trick’ to lower the 3dsmax resolution to minimum (aka 100x100) to reduce the memory consumption by 3dsmax Frame Buffer.
- Vray raw image : that what’s we use for rendering (multipart EXRs)
- Separate render channels will save all the render elements activated, while i just want a beauty. Like actually we can unsave RGB, we could have ‘RGB only’ option that would do the job.
