Double shadow, one light source?!
I’ve been using VRay for a few weeks (had some experience with it awhile ago, but usually just used a studio-style lighting template file a friend gave me). Everything was going great until yesterday when I started getting double shadows. That is, one shadow from the directional light I put in using the VRay sun system command and a second one from I don’t know where! See image below.
I’m using GI with a Sky (override sun settings is UNchecked). IRmap and Light cache.
I turned on all layers and showed all objects, SelLights and only get the one directional light I put in.
Any thoughts? Help would be greatly appreciated. Thanks!
Re: Double shadow, one light source?!
Please disable the default Rhino light through the Global Switches panel. The option is called “Default”.
Best
Thanks! That’s that setting I was missing.
also Double shadow, one invisible light source
Double shadow, one light source?! but with default lights off !!!
impossible to erase the default light … rhino doesnt ‘sees’ this light
