Can anyone confirm that double sided materials stopped working with version 1.5. I don’t recall there being a problem with it in 1.47. If so is there a work around or a way to do it using vray materials.
Thanks,
Rod
Thanks,
Rod
Ok I got the Vray 2-sided material to work. Must of missed that. However still would be nice if the standard double sided material worked for backward compatibility.
The standard 3dsmax Double-sided material has never worked properly with V-Ray. This is mostly the reason for the V-Ray specific one.
Ok, thanks for the quick response. Much appreciated.
