I’ve noticed when i send a render with DR turned on with IRmap set to -3 and -2 instead of doing 2 passes, the other computer picks up the other pass so it says pass 1 of 1.
Is this ok to use, i dont seem to have any weird results yet.
I thought this wasnt supported, i’m using vray 1.5 final.
It’s working correctly. Each core on the other computers contributing to DR is performing the IRmap calc in two passes (-3,-2) on a per bucket basis. So instead of doing two passes on the entire image (no DR) it’s doing two passes per bucket (with DR). The render status just list it as 1 pass as it sends buckets to the other machines.
