DR and irradiance maps
I was under the impression that you could save an iradiance map created from a DR in bucket mode and re-use it. Am I mistaken?
unless the latest versions allow for it now,
DR can’t save and reuse irradience maps.
as i know you can´t create a map from the bucket mode. when you want to use a stored map with DR, you have to calculate the map with ONE machine first. then the other machines in the network can use the stored map.
This would be a great feature to add in the future, but probably very difficult.
Distributed Irradiance maps and photon maps are planned for 1.1 as far as I know.
That will be really cool! Does anyone know the timeline for that release?
When its finished :wink:
-dave
??? I DONT GET IT
Hello ALL…
How do the slave machines access the irradiance map??? Also, do I have to place all the textures in a default map path on the local machines as well or can it be done with a UNC path to the server?
THANK YOU
Arkitec
I’ve got my maps UNC and on the server, the precalced Irrad map I copy local. either way they work, I’m still figuring out if it’s quicker to copy all the stuff local, I assume it is.
r2j2,
Thanks for the speedy reply. Well we copied the maps and irradiance map to each slave machine…and it worked.
However, several problems have occurred:
1.Everytime we use DR (hit the render button) viz requires me to RESAVE the file…EVERYTIME…When I first tested this, it only asked me when the defualt file was not save. This time, I am opening the file.
2. When i change a texture to an existing object, it does not update in the rendering. I am simply changing texture in diffuse map rollout, not a new mat slot.
Am am also crashing sporadically.
Am running win2k and version M
Any thoughts or comments?
TIA
Arkitec
sorry
I didnt realize that if I edited a post, it would not update time posted…Sorry..
Any help appreciated, on a deadline.
Arkitec
Where do you copy the map to on the local machine? Max root?
a
thank you for replying.
I created a folder on the primary disk called C:/Map2. I changed the ini file on all servers to include this path. I then created and directed my bitmaps to use Map2 folder locally.
TIA.
Arkitec
But why would this be any different than running a copy from the network server?
Sorry - modified the .ini file = max file - bitmap paths? Or vrayNet.ini?
thanks again.
a
We modified the 3dsviz.ini file to locate the maps locally because we do not want to have each rendering server logged in. The VrayNet.ini file is automatically created when doing a search through distributed rendering when you search for rendering servers located on the network.
Our current setup is working now. But we have written a batch script to copy all bitmaps located on my machine to be distributed to all rendering servers (i.e. c:/maps2).
For some unexplainable reason, viz is no longer asking me to save between renderings either or crashing. EVERYTHING SEEMS TO BE WORKING PERFECT!!! KNOCK ON WOOD…twice!!!
Arkitec
