DR and max 7 - working or not
hello guys, i have something really strange over here. i have DR working in one of my machines, but this machine is an old machine, so, i guess would be better to starts it from the stronger machine. but is impossible to do that. the old machine have 1gb of ram, the other one has 2 gb and i dont know what to do, i can have it working but why only in the weak machine? any tips?
same here, tried a few days without luck.
other DR solutions (banshee, finalrender) and normal network is just working fine.
the most strange is that it works, but not from the machine i would like it works. the smaller machine has only 1 gb and i guess i would speed up the render if i starts from the machine with 2gb of memory
i got it running for all machines except that one running windows server 2003. the other ones are using windows xp pro.
no problemos here
are you guys running it over SP2 and max 7?
not running SP2 yet
Running SP2 and MAX 7 here, no problems with DR so far. Only three machines, however. One is win 2000. No problems with it either.
Tony
what i can figure out is that there isnt a good profile, just some people can use it and some cant. In my case for instance, i can use DR from computer A to computer B, but not the opose. thats weird
the problem on our systems is, that the scene file that is copied into the slaves network folder is 0 bytes.
i hope that vlado looks into this, some other reported this too.
damn I seem to be having the same problem, couldnt get it to work, so I tried it the other way,
the licence + spawner is running on comp A
the client/max is running on B and it worked
so at least I can do it for the final render, but if it worked the other way around I could always use DR for everyrender :confused:
comp B is running 2000, and A is using win2k wonder if thats got anything to do with it
well I seemed to have fixed it
I changed the maps so they were all on my shared folder [mapped to the same drive on all pc’s]
that didnt help
but I noticed it wanted to save everytime I rendered [the dialog came up]
so I turned off incremental on save
and now it works!
I turned it back on just to see if it wouldnt work again, and it didnt work
YAY
so silver make sure you have incremental on save turned off
edit : well scratch all that, it is working with incremental on, so I dont know what fixed it - sorry about all the crazy talking to myself on the foum :slight_smile:
