Hopefully someone can help me here, I am using DR in max 7 and it works like a dream, the only problem is that only 10 buckets appear when i am trying to use 20 avalible buckets. I am using 4 licensed machines and 1 unlicensed render node.
Is there a reason why i am limited or is this normal??
Ok so I am assumming that you have 5 computer all P4 with HT. So 2 procs, each + you are counting the extra HT “virtual” proc as well. Making an effective 4 procs per computer x 5 which will give you 20. Right? It seems to me that the HT may not be working across DR. I would say that this is only a minor loss in performance since the virtual procs will only give you about a 10% to 15% boost. It may be a bug. Or it may be working, but DR is unable to find the “virtual” proc to use. I would report it as a bug.
I’m talking about multi-threading under customize/preferences/rendering in MAX.
It has to checked to enable dual processor support.
Check it on all the machines.
If you can see all the different buckets when rendering, then I don’t understand what the problem is. Each machine is identified by a different IP address, as you say. Is there a particular machine thats not working?
Just a thought, perhaps vray is not seeing the other liscenses from the other three dual machines and is only allowing the 10 computer limit that goes with a single liscence. That would definetly be a bug!
I am thinkg Egz that it is based on the number of buckets not on the ammount of pc’s that are running. I have about 30 processors that i have avalible to me for DR and it would be great to use them (we do a lot of large scale billboards)
No, the limit is 10 computers, regardless of how many processors in each. If you have 10 Windows Advanced Servers with 4 CPUs each you can render on all 40 processors with DR.
