3ds Max Design 2014 SP5
V-Ray 3.00.07
Windows 8.1 with all the latest updates
I recently updates to V-Ray 3.00.07…3.00.05 was working
DR does not work on two machines as well as V-Ray jobs sent through backburner. I tried sending a mental ray job and that worked fine…so I suspect V-Ray
also…my Windows 7 slave works fine
Thanks in Advance
Backburner log:
2014/05/28 21:02:38 INF Receiving new job from 192.168.1.105
2014/05/28 21:02:39 INF Job ‘master2’ received and ready
2014/05/28 21:02:39 INF Launching ‘Autodesk 3ds Max Design 2014 (64-bit)’
2014/05/28 21:03:29 INF 3dsmax adapter : Executing command line : C:\Program Files\Autodesk\3ds Max Design 2014\3dsmax.exe “-_pipe:479375” -server “C:\Users\Sean\AppData\Local\backburner\ServerJob\master2.max”.
2014/05/28 21:03:29 INF ProcessStarted processId=5040
2014/05/28 21:03:29 INF 3dsmax adapter : [V-Ray] ============================================================
2014/05/28 21:03:29 INF 3dsmax adapter : [V-Ray] Console created, V-Ray A for x64 from May 24 2014, 03:13:16
2014/05/28 21:03:29 INF 3dsmax adapter : [V-Ray] Compiled with Intel C++ compiler, version 14
2014/05/28 21:03:29 INF 3dsmax adapter : [V-Ray] Host is 3dsmax, version 16
2014/05/28 21:03:29 INF 3dsmax adapter : [V-Ray] V-Ray DLL version is 3.00.07
2014/05/28 21:03:29 INF 3dsmax adapter : Autodesk 3dsMaxDesign 16.5 is Ready.
2014/05/28 21:03:29 INF New task assigned: 0
2014/05/28 21:03:45 INF Adapter returned unexpected code -2 for “C:\Program Files\Autodesk\3ds Max Design 2014\maxadapter.adp.exe” “-o” “NewTask” “-l” “Info” “-j” “C:\Users\Sean\AppData\Local\backburner\ServerJob\master2.xml.details” “-s” “0” “-n” “1” “-a” “C:\Users\Sean\AppData\Local\backburner\ServerJob\master2.zip” “-d” “utf-8”
2014/05/28 21:03:45 ERR Task error: 3dsmax adapter error : Autodesk 3dsMaxDesign 16.5 reported error: An unexpected exception has occurred in the network renderer and it is terminating.
3dsmax adapter error : The pipe has been ended.
: 109
Are both V-Ray spawners running as a service? If yes, please stop them and try to start them manually. Do you get stable V-Ray dummy then?
Would it be possible to open 3ds Max on one of the problematic machines and load the V-Ray plugin there?
If there are any issues you may try to reinstall V-Ray and make sure to use “Run as Administrator” option.
I have not had a chance to start 3ds Max on one of the machines but I did stop the service (re-installed V-Ray 3.00.07 as admin) and manually started spawner…then a maxscript window opened up for the vraylighlister…strange. Maybe my profile is corrupt
also I tried installing V-Ray 3.00.05 as administrator and still the same issue
I started Max on the slave and V-Ray works…but DR still does not work (also re-installed V-Ray 3.00.07 as admin) - also deleted max user profile so it created another (C:\Users\Sean\AppData\Local\Autodesk\3dsMaxDesign\2014 - 64bit\ENU)
First please make sure that Vray License Server is configured properly to take its license from the machine where the dongle is plugged.
Next, please stop any V-Ray services from the slave machines.
Then start V-Ray spawner manually and pay attention to 3DSMax instance that loads with the spawner.
Does 3DSMax instance flashes,restart itself or it stays stable and when it is hovered with the mouse it prints “vraydummy2014.max”?
Except updating Vray to version 3.00.07 have you changed anything else on the system?
-the only thing that would have changed on the system would be windows updates (set to automatic updates)
- the 3DSMax instance flashes then stays stable …when it is hovered over with the mouse it does show “vraydummy2014.max”?
- I noticed when I sent a job that something flashes on the screen and then the icon disappears and then come back on. I assume that it’s just crashing (like the bb message above)
- for fun I set up a MR distributed render job and that woks fine.
- firewall is OFF
In order to eliminate any scene dependencies would you please perform one DR test on a very simple scene with a few primitives and a dome-light.
You could switch to Fixed Image Sampler with 10-20 subdivisions in order to slow-down the rendering, otherwise the main machine will finish the render before the slaves join it.
Once the test is finished please send the Vray Log file from the workstation and slave machine.
Please update us afterwards.
I’m embarrassed to say that it was something with the file that would not work. :roll: When I made the test scene as you suggested it immediately worked. I then merged in the file I was having trouble with and that worked. I was just a bit crazy in deadline mode and didn’t pause to test another scene. Thanks for helping.
Glad to hear it works now.
Feel free to contact us again if you have any troubles with it.
