DR problem
Hi to all,
I have some trouble with the D.R.
Some black stripe on the render and a message with the textures missing files (please see the attached picture).
I checked all of this on your help page :
  • Different gamma settings - make sure all gamma settings are set to correct values on all of your PCs OK !
  • Rendering from a camera object native to other renderer - it is recommended to use native 3ds Max cameras only OK !
  • Using plugins unsupported by Corona - make sure that all plugins you are using are fully supported by Corona OK !
  • Plugins missing on some of the nodes - make sure that exactly the same set of plugins is installed on all of the PCs OK !
  • Strips may also appear if the nodes cannot reach some assets such as textures or models. Please refer to the following articles:
    Missing maps/assets - DrServer is running with elevated UAC rights (as administrator) Required asset file could not be located OK !
All my slave have the acces to the nas in Z:/, the link is ok on max.
No troubles with vray DR.
Any ideas ?
Thx !
DR logs from the faulty node please?
https://coronarenderer.freshdesk.com/support/solutions/articles/12000002065-gathering-drdata-dr-logs-
Thx !
Here is the files in .rar
DrData.rar (24 KB)
is this not a case of using asset tracking to resolve path to UNC rather than using a mapped drive?
Usually you don´t need to convert to UNC when drserver is run as a standard user and the drive is currently mapped (I presume both of this), so there seems to be another problem. But it´s for sure worth a try.
Good Luck
I just know all our machines have the NAS mapped to N and I remember getting this problem. It may have been you that helped me and suggested using UNC :smiley: but ever since then it’s just part of my process for using DR otherwise I get missing textures.
Glad to read that. It´s only that I at least try to start to accept other peoples DR/BB approach even when I consider it the wrong way :wink:
Good Luck
Wow, a French Backburner! :smiley:
How about this line? Maybe something is missing on the faulty slave?
05/12/2016 14:07:01; ATTENTION Dll manquant: quad chamfer.dlm - Quad Chamfer
Yes !
French user too ! :wink:
Missing dll, strange …
I tested to lunch dr server and licence server without “as adminoistrator” and i think it’s work…
Oh, that might be an issue too. See: https://coronarenderer.freshdesk.com/support/solutions/articles/12000002048
Err … this is from your OP where you stated that you checked exactly that.
Good Luck
Ok !
Thx for the help guys !
